Go Back OFN Forums > Tech Section > Resources
Resources Find helpful charts, specs, recommendations
Resource Tools
Lens Shade Selector Guide
Don't know WHICH lens to use? Check here
Published by KeithXtreme
02-07-2006
* As a rule of thumb, start with a shade that is too dark to see the weld or cut zone. Then go to a lighter shade which gives sufficient view of the weld or cut zone without going below the minimum. In oxyfuel gas welding, cutting, or brazing where the torch produces a high yellow light, it is desirable to use a filter lends that absorbs the yellow or sodium line in the visible light of the (spectrum) operation.
Chopworx Motor Co.
Business# 918.607.3328
Chopworx.com
Resource Tools
Currently Active Users Viewing This Resource: 1 (0 members and 1 guests)
Resource Tools
HTML code is On
Resource powered by GARS 2.1.9 ©2005-2006
