Probably not what BT is intended for, but I needed to be able to visualize factory suspension mounting points from a production car in 3D.
BT made it fairly easy, from there I was able to attach some prototype arms.
Since I do not have SE or the sheetmetal module it will be simpler to make a set than to compete a drawing.
Since we are semi-locked into our homes I have been modeling all sorts of parts for the practice.
I have a basic multi-tube chassis design I am "virtually" adapting to several production frames using BT.
Next up is to create an updated and lighter space-frame design.
That requires a lot more tubes and triangulation so will be a test of my abilities.
