Old 10-15-2017, 11:34 PM
Mav01's Avatar
Mav01 Mav01 is offline
RZR XP4 turbo cage build
Hey all, new to the forum. Just purchased a JD squared model 32 hydraulic bender. I plan on building a cage out of .095 DOM and have it tig welded. I need advice in 2 spots. First is pick points for the bend tech. I can find them online for every RXR except the 4 seater. And 2nd, how does everyone attach the roof?
Thanks
Austin
Old 10-16-2017, 08:45 AM
The best setup I have seen for roof attachment has been a frame of 3/4-1" tubing welded to split clamps then the roof skin welded or riveted to the tubing. This will be very strong but far heavier than just aluminum skin with "P" clamps as is the normal method.
The split clamps can be aluminum or steel and the frame the same. Any time I have ever seen a sheet material attached with the industry standard "P" clamp the sheet or the clamp eventually fatigues and cracks.
Old 02-08-2020, 10:22 AM
utvwolfpack's Avatar
utvwolfpack utvwolfpack is offline
Thanks
Austin
We use Dzus buttons with Dzus weld tabs to attach the roofs
