Go Back OFN Forums > theOFN File Exchange (OFN-FE) > Bend-Tech
Bend-Tech Bend-Tech Assembly Files, Tooling and other unique tips and hints.
Old 03-24-2020, 04:08 AM
R3Fab.'s Avatar
R3Fab. R3Fab. is offline
Using BT to visualize factory mount points.
Probably not what BT is intended for, but I needed to be able to visualize factory suspension mounting points from a production car in 3D.
BT made it fairly easy, from there I was able to attach some prototype arms.
Since I do not have SE or the sheetmetal module it will be simpler to make a set than to compete a drawing.
Old 03-29-2020, 11:49 PM
EL VASCO's Avatar
EL VASCO EL VASCO is offline
Yes I agree BT is really great just would like to know how to take more advantage of it
Old 03-30-2020, 01:45 AM
R3Fab.'s Avatar
Since we are semi-locked into our homes I have been modeling all sorts of parts for the practice.
I have a basic multi-tube chassis design I am "virtually" adapting to several production frames using BT.
Next up is to create an updated and lighter space-frame design.
That requires a lot more tubes and triangulation so will be a test of my abilities.
Tags
alfa romeo, bt pro, prototype
