Old 08-01-2012, 06:37 PM
Gary123's Avatar
Gary123 Gary123 is offline
Trouble with EASB welder
My welder is continuously feeding the wire, does anyone know what I should check to see why this is happening?
Old 08-01-2012, 08:13 PM
shailerl's Avatar
shailerl shailerl is offline
Did you try unplugging the control wires from the machine. You may have a bad trigger switch or a short in the leads on the way to the switch. open up your wire tensioner so you don't keep wasting wire and try that first. Good luck. Shay
Old 08-01-2012, 08:33 PM
Might help to know just what model your talking about??
i am not sure but they did make more than one model.
Does it have a trigger lock??
Old 08-02-2012, 10:06 AM
Jaysusr's Avatar
Jaysusr Jaysusr is offline
The trigger switch if it were stuck on would produce gas and current as well as wire feed. So if its your trigger, good. That's a 10 dollar part. So if u don't have gas n current also, the trigger is not to blame
