Old 04-12-2011, 01:41 AM
RompinRam's Avatar
RompinRam RompinRam is offline
V Dub
Hey I am curious if there are any long travel suspension kits or even just beefier suspension kits out there for vw bugs. I would like to some day build an offroad basher but dont know what vehicle to start with. I dont have much money and I have come across many good deals on beetles on craigs list. Any imput would be awesome. Thanks
-Matt
Old 04-12-2011, 10:45 AM
DJPyro's Avatar
DJPyro DJPyro is offline
There're lots of options, both front and rear. Start looking.... Where abouts are you located? You can go anywhere from something with a little beefier tire on it and fresh, capable suspension, all the way up to a crawler with SAS swaps, or a long travel desert buggy. Depends on where you're using it and what you want to do with it.
http://www.dune-buggy.com/buggylinks/Baja_Bugs/
Old 04-12-2011, 12:36 PM
RompinRam's Avatar
Well I would like to make a desert runner. Somthing capable of taking whoops and jumps. I'm located in ca, orange county. I know long travel will get expensive really fast so I would probably settle with a decent set up to run through the desert without getting stuck.
Old 04-12-2011, 03:23 PM
smosher 604's Avatar
check out race-dezert yuo can pick up a semi built project bug or truck fairly cheap i sugest if your going with a truck get something with i beams you can get gobs of travel with a simple shock hoop and a coilover
Old 05-12-2011, 11:44 PM
gotlocker's Avatar
gotlocker gotlocker is offline
getting started with link pin conv. kit / mid travel conv. been in front of the monitor every night since new years. prototype will be o.g. sandrail chassis-there street legal in NC, tryin to get it to where you could weld it to just about anything but still fit under myers manx or baja.
Old 12-17-2011, 07:26 PM
GonzoTx's Avatar
GonzoTx GonzoTx is offline
Check out www.thesamba.com for everything V-Dub. They have a HUGE classified section with everything from lowriders to long travel, A arm off road setups.
