Old 07-27-2008, 03:21 AM
souledge's Avatar
souledge souledge is offline
Need help on the chassis for the buggy
I'm completely new to this fabrication field so please do ignore my silly questions if any.
We're at present building a Baja vehicle with a 250cc 9hp LOMBARDINI gasoline engine.I have doubts on the chassis and the rollcage of the vehicle.
Is it better if the chassis is inclusive of the rollcage or is building the rollcage separately and bolting it to the chassis more effective ?? the width of the vehicle cannot exceed 64 inches and the rollcage can only be steel.
Old 07-27-2008, 09:28 AM
BAILEIGH INC's Avatar
Sounds like a good candidate for Bend Tech Pro
Old 07-27-2008, 10:04 AM
On something that is this small I'd absolutely recommend that the chassis and the cage be one piece; if for no other reason then weight. The bolted joints represent a "potential" weak spot, they also will out weight the same linear length of tube by as much as 100x the length of tube the joint would replace.
I'll second the BT recommendation!
Old 07-27-2008, 10:16 AM
Bstomper's Avatar
Bstomper Bstomper is offline
I'll third the bend tec comment. It's the coolest thing I have seen in along time.
Old 07-27-2008, 01:37 PM
souledge's Avatar
Thanks a lot guys.......now moving on to the suspension system...what suspension type do you recommend for this config? The vehicle is rear wheel drive.As of now we've decided on A beam in the front...
Old 07-27-2008, 01:55 PM
"Beam" as in 'VW'?
"A" as in 'A-Arm'?
Not that i have an answer, I'm just not clear...
Old 07-28-2008, 12:29 AM
junk90xj's Avatar
junk90xj junk90xj is offline
x2 integrated into the chassis would be much stronger and lighter than bolting it on the the chassis.
Old 07-28-2008, 09:39 AM
souledge's Avatar
"Beam" as in 'VW'?
"A" as in 'A-Arm'?
Yup "A-Beam" as in 'A' shaped control arms
Old 08-27-2008, 05:36 AM
wolfy_9005's Avatar
wolfy_9005 wolfy_9005 is offline
Bolt and weld to chassis. That way it's strong enough if it rolls, and you only have to grind the welds off and replace it if it get's damaged.
Old 08-27-2008, 09:39 AM
No.
Old 09-29-2008, 05:43 PM
SUPERD's Avatar
SUPERD SUPERD is offline
Thats why it's called an "A" arm, a beam suspension involves torsion bars or leaves
Old 05-14-2009, 06:53 AM
rocksolidfabrication's Avatar
rocksolidfabrication rocksolidfabrication is offline
Ok im very very new to this site, havent even posted yet. but ive been reading articles every single day on this site and im not trying to bash anyone or anything but it really seems like everytime someone has a problem that is a newbie the owners of tool supply companys and people who seem to work for bend-tech seem to chime in and just say o go buy our $500 software and thats about it, i mean im sure the software is AMAZING but everyone here knows that this software wasnt always available and there is other ways of doing it which might be alot more helpful in the long run then software, LEARN FROM DOING! just face the fact your gonna waste tons of tube and start bending. Again im not trying to be rude and sorry if i am.
Old 05-14-2009, 08:10 PM
nhrocker's Avatar
nhrocker nhrocker is offline
It's not that everyone in here works for them, its that the program is that good. I personally can't wait till I can buy it. I've seen others use it and have been amazed at how much simpler it can makes things.
That's one of the things about BT that makes it worth buying. Why would you waste tube when it's not necessary? I just finished pricing up the steel for some upcoming projects and the tube I need runs about $130 for each 20' length. If I "learn" on two pieces of tube I just spent $260 making scrap. I could have spent $275 on BT Pro and not wasted that material. With the amount of tube some of my builds will be using BT will pay for itself within the first project or two.
And like I said, this is coming from someone who doesn't even own BT yet, let alone work for them. You better believe I'll be praising it even more once I get my hands on it.
Old 05-15-2009, 03:43 PM
The only one here that 'works for' Bend Tech is Cris (Fabcam), but it is more like he is the owner of Bend Tech. He also owns,operates, and pays the bills to have the OFN here on the internet for all of us to enjoy. So yes all of us that enjoy the awesomness of Bend Tech, and the ones that know what it does, do our best to steer the 'noobs' in the right direction at the same time helping support Bend Tech, which in turn helps us all. And it doesn't necessarily cost $500 to get Bend Tech, I believe you can get the basic version for under $100 and upgrade as you need, only paying the difference to the next level.
I'm not saying you can't bend tube without Bend Tech (I did it for years), but if you intend to do any decent amount of tube bending, why not make use of it. I view it as "stepping into the 21st century"
Old 10-15-2009, 11:32 AM
Fab-Ex's Avatar
Fab-Ex Fab-Ex is offline
I have to chime in on this one. With the 321 buggy kit coming in at ~$3000 and tube at ~$100/stick a person could buy bend tech at $275, 10 sticks of tube ~$1000 and a bender ~$500 and single die $300 and be roughly $1000 ahead wich should pay for your time to design and build. Now you are a little older have a buggy chassis a grand in your pocket unless you spent it on beer during the build and some kick ass tools. Don't forget that now you can build a buggy for some buddies and put a little more coin in your pocket.
