Old 11-17-2015, 10:38 AM
Thumbs up Step Drill For Sheet Metal
I feel like such a stooge for not buying step drill bits until now. OMG they are amazing for holes in sheet metal. Butter smooth, fast, no catching, no shrapnel, and nice clean hole. Wow.
By contrast, when I use twist bits for sheet metal holes, especially if the sheet metal is unsupported, as holes get bigger than about 1/4" the bits will start wandering and then catch/bite hard, resulting in bent metal and a mangled ID. The problem is not solved by drilling in multiple steps, even when going in 1/16" increments.
The step bit remains always piloted on the hole by the previous step, which keeps it engaged nicely. So it doesn't wander and bounce around on the hole before suddenly cutting in like a twist bit does. Instead it cuts smoothly and quickly, producing a nice clean, round hole without bending the surrounding panel.
Money well spent.
Old 11-17-2015, 10:50 AM
Money well spent.
I had the same experience and revelation. They also work great to break the edge on a hole in thicker metal, even chamfer all around. All good.
Old 11-17-2015, 10:51 AM
Those are great. Like you, I can't believe I did without them as long as I did. They are definitely one of those tools you kick yourself for not buying sooner. Another one of those for me is a rotary file.
Old 11-17-2015, 11:29 AM
Ditto, I learned on plastic or fiberglass a long time ago. I couldn't believe how much better they were. Now I use them constantly.
Old 11-17-2015, 11:44 AM
Same here. Anything 1/8" or less gets the step drill treatment if I can't punch it. I also have a set of the Jancy/Fein small hole cutters that get a ton of use on stuff up to 1/4" thick.
Old 11-17-2015, 01:40 PM
Do you have a picture or link to the Jancy cutters?
I have no idea how many times I have told people to get sheet metal step drills and they say "I don't need them" only to have them use mine and then say "why didn't you tell me they worked so well". People rarely really listen.
Old 11-17-2015, 01:46 PM
Sure, this is the kit I have:
http://www.trick-tools.com/Slugger_S...Set_SMS000_429
My only criticism is the pointed center can jump out of a center punch mark if it's not large enough. On critical stuff, I will drill a 1/8" pilot hole to make sure this doesn't happen.
Old 11-17-2015, 04:57 PM
I use the heck out of step bits. In fact Ive had pretty good luck with the :gasp: Harbor Freight ones. I get the sets on sale for $10 or less sometimes. I have some good sets as well, but honestly for a weekend warrior the HF ones perform pretty well considering they are a fraction of the cost of a "real" set. I also like the 1/4" hex quick change shank as you can put them into long bit extensions for drilling holes with limited access. (hard to reach spots on a firewall for example)
Old 11-17-2015, 07:44 PM
Anyone had any luck sharpening them? I always seem to burn one of the steps then its a real bitch to get past. I tried sharpening one with a round stone on a die grinder (zero precision) it seemed better but quickly got back to the burned step where it evidently didn't help.
