Go Back OFN Forums > theOFN File Exchange (OFN-FE) > Bend-Tech > Tooling Calibration > PRO-TOOLS
PRO-TOOLS PRO-TOOLS tooling results
Old 02-25-2011, 10:12 PM
UNSTUCK's Avatar
UNSTUCK UNSTUCK is offline
I need Calibration help: Protools 105
A guy in my local club is looking for some help with grill hoop he needs bent, only he's WAY far from me so I can't get to him. Anyways, he asked me to design the hoop and get him the instructions so he can build it with his bender. I'm trying to get the calibration numbers for a 1 5/8 die with a 6 inch radius. This way I should be able to get it close for him.
Thanks.
Old 02-27-2011, 01:50 PM
flatblack51's Avatar
flatblack51 flatblack51 is offline
guide him through the tutorial on bend tech to get the correct numbers. take 3' 1.875 tube mark it 4"(mark loc) bend a 90* and measure each leg.... and give you the numbers every bend is different. I used the generic numbers and came up 3" short then calibrated and its spot on now
Old 02-27-2011, 04:25 PM
Thanks.
There are other factors to consider. Like said above,you need to calibrate. There are some numbers here http://www.offroadfabnet.com/forums/...bration&page=2 Post #39
You still need bend location offset.
Calibration guide here>>>http://www.2020softwaresolutions.com...ad/cgrev03.pdf
Old 02-27-2011, 10:03 PM
UNSTUCK's Avatar
Yeah, I sent him the calibration guide yesterday, so it's in his hands now. Hopefully he can get the numbers right.
Thanks for the help though.
Old 02-28-2011, 10:20 AM
The part you are making.... The template is a little tricky. Make sure you use Verify under the Misc tab when you are done to make sure you are getting what you are planning.
