Go Back OFN Forums > Marketplace > Vendor Marketplace
Vendor Marketplace Special deals and offers from OFN Vendors!!!
Old 07-01-2008, 08:09 PM
divtec's Avatar
divtec divtec is offline
Thumbs up ParkerMP - Plasma Cutters, Plasma/TIG/Stick Combination, TIG, MIG Welders & Accesorie
PRODUCTS OFFERED:
PRECISE-WELD200ACDCSSV (200AMP ACDC TIG/STICK COMBINATION) $999.99 - $100 (OFN MEMBER DISCOUNT) = $899.99, COMPLETE OUT OF THE BOX OPERATIONAL! (INCLUDES FOOT PEDAL, ARGON REG/FLOWMETER (FLOATING BALL TYPE... ALL YOU NEED IS ARGON. DRAWS ONLY ABOUT 30AMPS ON 220V... SO YOU CAN RUN IT THROUGH A LONG EXTENTION CORD... PORTABLE!
PLASMA-TEC40DV (DUAL-VOLTAGE AUTOMATIC) 40AMP PLASMA CUTTER, RATED CUT: 5/8", SEVER: 3/4", 20 LBS AND THE SIZE OF A LARGE LUNCH BOX, DRAWS ONLY 22AMP MAX ON 220VOLT AC (PORTABLE RUN IT THROUGH 150' 12/3 IF YOU WANT), ALSO FOOT-PEDAL OPTION (PRECISE CUT/GOUGE DOWN TO .005") WEBSITE PRICE: $499.99 - $100 (OFN MEMBER DISCOUNT) = $399.99
PLASMA-TEC40/160DV (DUAL-VOLTAGE AUTOMATIC) 40AMP PLASMA CUTTER, 160 AMP DC TIG/STICK, 33 LBS, THE SIZE OF A BREADBOX, DRAWS ONLY 22 AMPS MAX @ 220VOLTS. $699.99 WEBSITE PRICE - $100 OFN MEMBER DISCOUNT = $599.99
WE HAVE OTHER MODELS TOO.
GENERAL
WARRANTY 1 YEAR LABOR, 1 YEAR MECH. PARTS, 3 YEARS ELECTRONIC PARTS.
TOLL-FREE TECH. SUPPORT (AND WE ACTUALLY ANSWER THE PHONE).
REFERENCES: CHECK OUT WHAT SlightlyModified (Master Fabricator) HAS DONE WITH OUR PW200ACDCSSV MACHINE.
QUESTIONS/DETAILS/INFO/ORDER 888.281.2820 OR 480-983-6030
LATER... PHIL SR
ID:	3807   Click image for larger version
ID:	3808   Click image for larger version
Old 03-11-2009, 10:45 AM
jeepmonkey's Avatar
jeepmonkey jeepmonkey is offline
PM'ed
Old 03-11-2009, 12:05 PM
jeepmonkey's Avatar
divtec are you still on this site? does anyone know anything about these parker plasmas? Any good or just a post on here?
Old 03-11-2009, 01:49 PM
wallnut's Avatar
wallnut wallnut is offline
I have a 40 amp plasma single voltage from parker it works great never an issue. I am a weekend warrior though, largest I ever cut was 1/4 inch though. It did cut well with my limited experience. Check and see if they have any scratch and dents save some money, usually about a hundred.
parkermetalworking.com is the sight.
Old 03-11-2009, 03:12 PM
Ladderbar's Avatar
I have a 60. Had a problem with the tourch they took care of it. Nice people to deal with,for me any way. I do not use mine every day but I use it enough. I would buy another.
Old 03-11-2009, 10:44 PM
shaggy10000's Avatar
Couple years ago i sent them some e-mail's asking to see them first hand at their shop. Since im just a couple hour drive away. Never heard a single thing back from them.
I've heard good things about them, mostly their customer service. Go figure.
