Old 07-21-2017, 08:35 AM
Originally Posted by Graham08 View Post
Looks great! I've been following along on IG, too.
Which version of Dynafile did you get? That's pretty high on the list of tools I want to pick up.
Pictured below.
Dynabrade is part number 14000 and the floating contact arm is pn 11219 (bottom arm without the platen, a must have for finishing anything round).
https://www.zoro.com/dynabrade-air-b...00/i/G3606827/ (you should be able to find a 20 or 25% off coup which brings this down to around $380-400. Its worth every single one of the pennies.
and
https://www.zoro.com/dynabrade-conta...19/i/G3701957/
I also picked up this contact arm as it has a small wheel at the end you can use to do a nice fillet in corners (middle arm in pic).
http://www.lehighvalleyabrasives.com...11213-dyn11213
As for belts. Check out Perfect Sanding Supply on ebay. They have the best price a couple of us could find. They are german made.
http://www.ebay.com/itm/1-2-x-24-San...72.m2749.l2649
Hope that helps! Def buy one, you will not regret it one bit.
Old 07-21-2017, 09:17 AM
Put the brushed finish on the rear exhaust section last night. I sanded out all of the tooling marks and then used the maroon belt on the dynabrade to do the brushed finish. All thats left now is a tail pipe which Im still undecided on.
