Old 06-10-2011, 12:13 AM
noahfecks's Avatar
noahfecks noahfecks is offline
Dimple Dies
Just started playing with my BTSM and wondering if there was a way to put my dimple dies into a tools library the way I can for my materials and and bender dies?
Old 01-13-2015, 12:23 AM
quadboy's Avatar
quadboy quadboy is offline
Im trying to do the same. Wonding if you figurd it out.
Old 01-13-2015, 01:45 AM
There is no need for inputting those into a library. In plate you select hole from the menu and then dimple. You can change the inner and outer dia. and height of the flare.
Old 01-13-2015, 09:11 AM
Also the direction of up or down.
Old 07-14-2015, 10:09 AM
Bray D's Avatar
Bray D Bray D is offline
I'm using dimples in a current build, and I can visually see the protrusion in the software but I'm not seeing the rolled edge on the top side of the dimple (created with the male portion of the die). Not a huge issue, just an observation.
Is this typical or am I missing something? 7x version of SE.
Old 07-14-2015, 10:32 AM
Each different manufacture makes their dies a little different giving a little different look and pitch to the material. We are using a representation of the dimple to provide a little of the look that it will provide. We opted to not got into all of the different values needed to create the "perfect" geometry because it would cause more confusion then help to the customer.
Old 07-14-2015, 12:47 PM
Bray D's Avatar
Super quick response - awesome!
I'll take some screenshots tonight so everyone can see what I'm talking about. It's not an issue by any means. I was just curious.
Old 07-15-2015, 12:02 AM
Bray D's Avatar
Top
Bottom
Old 07-15-2015, 10:11 AM
I will check into it.
