To make this work I have to put compression tubes through the ball-joint end of the tubes.
It may be simpler to replace the green 1.5" tube with an assembly made from plate.
Light blue are the compression tubes, length to be adjusted for the taper of top and bottom plates.
Orange is the ball-joint mount.
Grey 1.00" tube fraction visible between the green tubes would not exist, trimmed away, but I cannot render that with BT.
And yes I did add a cross-brace.
Once welded up this should be quite strong.
My concern then becomes that if I ever need to replace the ball-joint, will I be able to remove and exchange it?
