Old 09-20-2012, 11:17 PM
johny5's Avatar
johny5 johny5 is offline
It's been pretty cheap so far
I'm not sure but hoping to be around 8-10k tires and gears/lockers are going to
to be the big ticket item.
Old 10-11-2012, 11:03 PM
johny5's Avatar
Did a little work the last few days, got the shifter mounted , it was a bit tricky
because the shifter used to be behind the engine , now its in front.
I added the extension on the bottom of the shifter therefor reverencing how the shifter works. (the cable used to come from the other direction )
I wanted to re use the stock shifter because I had it and because the of wiring in has in it.
Also mounted the winch , Its an old winch I had , narrowed it 4 inches.
need the winch mounted so I can start the floors.
hoping to rotate the winch free spool so I can put an extension on it and work it from the dash
Also mocked up the skid under the seat . It will be 3/16 AR plate
Old 10-16-2012, 05:11 PM
More nice work Johny,thanks for posting
Just wondering why your spending on gears?you don't have any or you dont think ratios will suit?
Old 10-17-2012, 03:33 AM
johny5's Avatar
thanks , the stock gearing is pretty high ratios 3.73 stock . I have some 5.29s on there way.
I like low gears . hopefully its not too low of gearing though
Here's a short video of my other buggy on Vancouver Island. Its not normally this dry over here but it was sure nice for rock crawlin
http://www.youtube.com/watch?v=RUzUT...=youtu.be&hd=1
Old 10-21-2012, 09:52 AM
Nice thanks for posting,i would have thought gearing would be ok but 3.73 is fairly high
Any idea of trans final drive ratio?sorry if you already mentioned
Old 11-13-2012, 08:09 AM
Dirtslngr's Avatar
Dirtslngr Dirtslngr is offline
any progress?
Old 11-13-2012, 11:32 AM
Sarcastro's Avatar
pretty awesome!
Old 11-13-2012, 08:31 PM
johny5's Avatar
Thanks , I have been busy working on a customers buggy , hoping to have that out of the shop soon , then it's back to the single seater
Old 11-24-2012, 12:08 PM
BMan's Avatar
BMan BMan is offline
Subscribed!
Looking great man!
Old 11-24-2012, 12:25 PM
johny5's Avatar
Thanks
Not too much new to report been collecting parts , got a good deal on a rear suck down winch at a black Friday sale.
Starting full time job on top of my part time business in the next few weeks so my shop time is going to be even less, but if all goes well I'll have a pension one day
I did do a rough brake down of money I have spent ,just over 7K
I have most every thing now but Im sure there still will be another $1000
Sill a lot cheaper than my V8 buggy
Old 11-26-2012, 06:16 AM
Congrats on the full time job,hard come by over here these days.
Hope to see more of the buggy soon.
Old 12-17-2012, 03:03 AM
johny5's Avatar
Thanks , I got the weekend off so it gave me a chance work on the buggy.
striped the wiring,mounted the computers for the engine and transmission
also made up some interior panels.
played around with the fuel cell as well (my buddy is building it for me ,I just need to rough fit it)
Old 12-22-2012, 11:19 AM
Nice
cant handle auto elec's at all myself
Old 12-22-2012, 03:06 PM
johny5's Avatar
Thanks
It's crazy how much wiring is involved with this little rig , with the auto it adds a lot of extra wiring
Old 12-25-2012, 01:50 PM
rockape's Avatar
rockape rockape is offline
Are you planning to use the stock honda intermediate shaft as part of the rear driveline? If you have room,it seems like it would make a great place to do a rear driveline disconnect.
You may want to rubber mount your ECU.... I recently had my socketed one go bad on me.Im pretty sure it was from being solid mounted. Also do your best to keep it dry,honda ecu's arent even slightly sealed for weather exposure and cook pretty easily....
Build looks good.....if you have any of those knuckle balls laying around send them my way!!! :-P
Old 12-26-2012, 12:34 AM
johny5's Avatar
Thanks . The knuckle balls are stock that I spun up in the lathe .
I will try and isolate the the computers and keep them dry , I don't think I'll be able to use the intermediate shaft . I do have a pair of ARB,s so I'm hoping that and cutting brakes will do the trick
Old 12-31-2012, 01:00 AM
johny5's Avatar
did a little more in the last few days
Old 01-05-2013, 01:52 PM
Mud-Nut's Avatar
Mud-Nut Mud-Nut is offline
Nice work dude!!!! Love all the fab work, it's very impressive. I'm looking forward to future updates.
Old 01-05-2013, 02:31 PM
johny5's Avatar
Thanks , gears and lockers are being set up next week and I'm working on the wiring right now , also have more aluminum coming to do more panels
Old 01-05-2013, 08:14 PM
Wow! Nice job. You're quite the fabricator.
Is that a common size tubing?
