08-12-2017, 05:13 PM
I got some prep work done , getting ready to install the glass.
08-13-2017, 05:30 PM
more progress.... i also installed the whiskers, glass bumpers and guide channels.
08-13-2017, 05:45 PM
i just spent the time as a newbie around here to go through your build thread a bit. Very impressed. Bloody well done that man.
08-14-2017, 09:26 PM
Thank you !
08-20-2017, 12:00 PM
09-10-2017, 09:17 AM
Last friday Sept 1 I got insurance and a plate. That weekend I finished assembling and installing the windshield. Then took it up my road about a mile to the dead end and back to the house. looked everything over then went for a drive, about 5 miles. after getting out of my neighborhood, making a left onto a main road I hammered it. It down shifted into first and the rear started skating around slightly. It kept spinning through the shift into second and then i lifted. Sorry, no video. I could see a faint pair of 18" wide black tracks in the rear view mirror. It loud as hell at WOT.
09-10-2017, 11:36 AM
Thats got to feel good! Congrats.
09-12-2017, 10:17 PM
What felt even better is when I got back to my house after the hurricane passed and I found my shop intact and the house has minor damage. As soon as the traffic light are working, I'm going drive it around here in naples.
10-11-2017, 10:37 AM
well... apparently you are supposed to put gear oil in a Dana 60 before you drive your hot rod. ooops. i'll post pics when i can. highlights: diff locked up at about 45 mph. made 175' dual 18" wide skid marks. no skid marks in my shorts. everything looks ok with the exception of the front pinion bearing and preload shims. that happened at about 7:15 sunday night. I got up at 6 monday morning and had it all torn down by 7:15 am. replacement parts already ordered.
10-11-2017, 10:48 AM
Been there done that, except it was a 14B and I was flat towing the rig.
10-21-2017, 05:33 PM
added a 3rd brake light using the same model Yankee tail light i have for the other 2. Also made a valance out of some scrap sheet metal I had. I have no idea how I could get this lucky, but the unpainted surface looks almost identical to the rest of the body. I did nothing to it to alter the appearance. I am going to adjust the valance some. It needs to be a little bit narrower and the passenger's side fender needs a little work to even up the lower edge of the valance.
10-29-2017, 08:28 PM
Just drove it about 9 or 10 miles. I checked the temp of the diff housing when I got back and it felt normal, warm but not hot at all, so that's a good sign. The exhaust is dual 2 1/2" race magnum bullet mufflers with turn downs that are 1/2 way between the back of the cab and the rear axle. It's obnoxiously loud pretty much all of the time but the idle does sound pretty good. im going to have to change them but I haven't decided on anything different yet.
03-04-2018, 10:48 PM
03-04-2018, 10:49 PM
drove the truck when we went out to dinner last night. I thought this spot would be good for a picture but there's bad shadows and the background building color is not great for a rusty truck.
03-05-2018, 12:42 PM
Big flat panels are susceptible to oil canning and vibration. Probably would have helped to put a few stiffening beads in those. The lining looks good though and if it works, it works!
Not a bad picture at all. Time of day and cloud cover can really affect lighting. I haven't done any glamour shots of my Nova, but when I do attempt rookie photography I try to do it early in the morning when there is still some overcast which helps diffuse the light and prevent shadows. Dust/evening shots like yours can be great too because the evening sun offers a warmer light, but it can be hard to position the car to manage shadows and reflections.
Truck sits just right. I love the deep/wide meat out back and the big steel wheels.
04-10-2018, 08:07 AM
what diameter tire are you running in the back ? I'm working on a 39 Plymouth pickup, I love the stance on your truck you nailed it , awesome work on the whole truck by the way
06-20-2019, 02:08 PM
it's 11 gauge and I added an inner panel, you can probably stand on it.
06-20-2019, 02:09 PM
The tires have been discontinued for years. 29 x 18 x 18
06-20-2019, 02:11 PM
the following posts will be updates from 4/5/18 until 6/20/18
06-20-2019, 02:12 PM
Powered by vBulletin® Version 3.8.0 Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
