Old 05-21-2015, 11:42 PM
chickenwings_85's Avatar
chickenwings_85 chickenwings_85 is offline
V3 Long travel transmission question
Hello, I'm in the process of getting everything together for the V3 plans I purchased. I was looking at transmissions and received some info on here before, but I had an idea I wanted to toss out and see what everyone thought.
Has anyone here used a 4T80E transmission out of a FWD chevy/olds/caddy for a mid engine setup in a long travel buggy? I'm planning on running a 5.3 LS4 engine and from what I've read it will bolt right up. the only difference is that it will be rotated 90* from it's normal position. I also read that they are pretty stout and with a build they can handle a beating. I'm not sure how the CVs will work but if I need to modify something I can probably make it. I run CNCs at work and I shouldn't have any problems cranking out an adapter if needed. If I can make this work it would be much cheaper than the Fortin or Mendeola options.
thanks for any info
Charles
Old 05-22-2015, 08:40 AM
Rotated 90 from its normal position?????
Old 05-22-2015, 10:20 AM
Its tranverse engine right vs the older Toronado configuration.
Old 05-22-2015, 12:00 PM
A 180 turn I get but a 90?
Drive now running F2B?
Old 05-22-2015, 12:29 PM
Normally a V8 would sit front to back in a long travel. If I run the 4T80 transaxle I have to rotate the engine 90* so the axles will go out the sides. If it was rotated 180* the axles would be running front to back.
Old 05-22-2015, 12:31 PM
Yeah it's getting pulled from the Cadillac STS/DTS cars that had the FWD northstar power plants. You can grab one from a junk yard for $250.
Old 05-22-2015, 02:38 PM
Lack of sleep... I was just not getting it
Old 05-22-2015, 02:44 PM
Ok.
Most OEM transaxles for FWD Cars are really wide at the Inner or DOJ. This to eliminate plunge and thus slip joints on the drive-shafts.
Comparatively...
That will make the track width of your suspension really wide or you will have short wheel travel before you take the CV's our of their operating range.
AND I could be completely wrong!
Old 05-22-2015, 06:29 PM
Originally Posted by entropy View Post
Ok.
Comparatively...
Ok, thanks for the response.
I may just buy one and see if I can do a mock up. They are super cheap. I wonder if I could get some wheels with a large offset to reduce the rear end width. I believe the 4T60 is not as wide but would need to be built as well. I'm not sure if the 5.3 will bolt to that transaxle though.
Old 05-23-2015, 11:46 AM
If you design the suspension correctly there are wheels that could have enough offset to give you a few inches per side but verify your tires will fit the rims first.
Old 05-23-2015, 01:28 PM
I should also say to check that the wheels are rated for your tires.
Old 05-24-2015, 03:02 AM
Ok, I know I wont make up all of the travel that is lost but if I can get it pretty close I'll settle for that. Thanks for the input, I'm new to all of this stuff so it really helps.
