Old 11-19-2015, 11:22 AM
mdslngr77's Avatar
mdslngr77 mdslngr77 is offline
I use these quite often for metal line work
Old 11-19-2015, 07:34 PM
I told you.
Should have bought a TIG machine to weld the MAF block on. Now you can weld up some A/C lines. Glad I could help LOL.
A buddy has a LS'ed JK Jeep with lines made Like Entropy said, they look pretty factory.
I am not a fan of the ez clip hose stuff either, I also have been cut pretty badly from those clips on heavy equipment. Like sticking your hand on a cheese grader.
Old 11-19-2015, 07:44 PM
This doesn't help with flaring the tube but there is a ton of A/C info in here. There are some -8 pieces of tube in there with the flare already in here. Look in the oring to flare adapter section.
Red Dot Aftermarker Catalog
Old 11-20-2015, 11:29 AM
mdslngr77's Avatar
EZ clip is great for its durability and ease of repair in the field, I use it on m heavy equipment installs but it can be ugly if thrown together without planning well for the install. You can get reduced barrier fittings and hose to use with a crimper that aren't as large of an outside diameter hose. I'm a Red Dot and Airsource dealer and I've found Airsource (MEI) has a better selection of repair and install fittings than REd Dot.. Weatherhead has a good selection also.
Old 11-21-2015, 11:07 AM
AlxJ64's Avatar
AlxJ64 AlxJ64 is offline
I'm putting together an AC system in my '42 Dodge Carryall and was looking into what would be needed for some nice Hard lines. Looks like you can convert somewhat to a 45 degree flare system.
I have ordered some parts from these guys and its been good stuff for the price and ships at lightening fast speed. 45 degree flare looks easily done with the Mastercool unit posted earlier in the thread. 45 degree is the angle of a brake line bubble flare too right? So you could probably use a 3/8" brake flare tool to run your -6 size hard hoses.
https://coldhose.com/specialty-fitti...-adapters.html
Old 09-10-2020, 07:42 AM
MichMurray's Avatar
MichMurray MichMurray is offline
Old thread but anyway it depends on the diameter of the tubing but I have a Mastercool brake and fuel pipe flaring tool which can do those. In general, whenever my A/C breaks down, I always turn to special services because I don't have much time to solve everything on my own because I'm busy with the service.
If someone needs it, I can recommend quality repair of air conditioners because I know how important it is to go to a good specialist who will surely do everything qualitatively and there will be no problems in a while. I hope you find it useful..
Old 11-23-2020, 07:22 AM
totolover's Avatar
totolover
Guest
Posts: n/a
Dont ever try to repair ACs yourself, you might end up causing more damage. I agree with you, its best to go to reliable aircon services to look profressionals for maintainence! Cheers.
